I have purchased a license in 2010 and i cant seem to be able to put in the lecense for the version 9 its a lifetime license i boufgt from dvd fab and they say i hev no purcheses when i registered to the version 9
dvd fab 8 to 9
You must create an account in the Member Center, here: http://www.dvdfab.com/member.htm?a=register&t=per using the same email you used for purchase and a password of your choice. After you do that use the same email and password to register v9. Internet connection required. There is no key to download. If the email is rejected, contact the Support team in Beijing using the Contact link on the website (not here).Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
