Hi there,
with release 9047 on win7pro (64bit) I can't rip the bluray of "Terminator 2 - Limited Edition". Any ideas how to solve that?
Kind regards nase44
DVDFab 9.0.4.7 (2013/07/01 16:16:38)
1m 38.87s: opening iso X:/T2_FEATURES.iso
1m 38.87s: got media type 15
1m 38.90s: got max lba 23839359
1m 38.97s: got disc type 20
1m 38.97s: type Blu-ray BDMV
1m 38.97s: volume label T2_FEATURES
1m 39.01s: internal path c:/BDMV/
1m 39.11s: aacs 0 bd+ 0
1m 39.18s: got bdmv
1m 39.18s: movie name: Terminator 2||T2_FEATURES
1m 39.38s: got bdmv
1m 43.21s: got extended bdinfo
1m 43.21s: opened blu-ray
1m 44.01s: Work Profile : mkv.default
1m 51.41s: Work Profile : mkv.default
1m 54.92s: Start check Blu-ray Ripper (3D Plus) register status.
1m 54.92s: End check Blu-ray Ripper (3D Plus) register status: Enable
2m 04.64s: OPList at BD Ripper : (4113.2),(4352.1),(4354.1),(4355.1),(4356.1),(4357 .1),(4358.1),(4608.16),(4610.16),(4612.16),(4614.1 6),(4615.16),(4617.16),(4618.16),(4620.16)
2m 04.64s: Blu-ray ripper (3D Plus) check watermark flag: 0
2m 04.66s: ------------------ convert work begin(1/1) ------------------
2m 04.66s: info: create config(bluray2video)
2m 04.66s: info: use profile(mkv.default)
2m 04.66s: info: bluray playlist(20),angle(0),chapter(1->81),BDAV(no)
2m 04.66s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
2m 04.67s: info: video stream[4113][codec(vc1) opcode(compress)]
2m 04.67s: info: set output video frame_rate(25/1)
2m 04.67s: info: audio stream[4352][codec(dca) channels(6) sample(48000) bitrate(0) opcode(copy)]
2m 04.67s: info: audio stream[4354][codec(dca) channels(8) sample(48000) bitrate(0) opcode(copy)]
2m 04.67s: info: audio stream[4355][codec(ac3) channels(2) sample(48000) bitrate(224000) opcode(copy)]
2m 04.67s: info: audio stream[4356][codec(ac3) channels(2) sample(48000) bitrate(224000) opcode(copy)]
2m 04.67s: info: audio stream[4357][codec(ac3) channels(2) sample(48000) bitrate(224000) opcode(copy)]
2m 04.67s: info: audio stream[4358][codec(ac3) channels(2) sample(48000) bitrate(224000) opcode(copy)]
2m 04.67s: info: Subtitle Mode(Extract) -- Display only forced Subtitle(false)
2m 04.67s: info: subtitle stream[4608][codec(pgssub) language(English) opcode(extract)]
2m 04.67s: info: subtitle stream[4610][codec(pgssub) language(German) opcode(extract)]
2m 04.68s: info: subtitle stream[4612][codec(pgssub) language(English) opcode(extract)]
2m 04.68s: info: subtitle stream[4614][codec(pgssub) language(German) opcode(extract)]
2m 04.68s: info: subtitle stream[4615][codec(pgssub) language(English) opcode(extract)]
2m 04.68s: info: subtitle stream[4617][codec(pgssub) language(German) opcode(extract)]
2m 04.68s: info: subtitle stream[4618][codec(pgssub) language(English) opcode(extract)]
2m 04.68s: info: subtitle stream[4620][codec(pgssub) language(English) opcode(extract)]
2m 04.69s: try to use gpu acceleration(1) for video decoding
2m 04.70s: CUDA GPU acceleration for video decoding enabled
2m 04.74s: CUDA GPU acceleration for video encoding enabled
2m 04.74s: info: h264_encode: encode param profile(2) level(41) bitrate(5876)
2m 04.81s: info: processing source(00000.m2ts)
6m 44.86s: info: processing source(00001.m2ts)
7m 10.30s: info: processing source(00002.m2ts)
7m 48.58s: info: processing source(00221.m2ts)
8m 59.34s: info: processing source(00030.m2ts)
13m 30.19s: info: processing source(00031.m2ts)
14m 24.97s: info: processing source(00005.m2ts)
14m 32.57s: info: processing source(00006.m2ts)
15m 28.63s: info: processing source(00007.m2ts)
15m 43.18s: info: processing source(00008.m2ts)
21m 08.28s: error: filter name(bd_demux), type(1), id(25), get std_exception(bad allocation)
25m 34.98s: error: Work 1 failed, Error = graph control_filter_error error: filter name(bd_demux), type(1), id(25), get std_exception(bad allocation)
25m 34.98s: ------------------ convert work failed ------------------
Kind regards nase44
1m 39.18s: got bdmv
1m 39.38s: got bdmv
