Howcome on the new versions of DVDFab v9 releases then you don't get any info after you have made a avi, example before when you right click and properties you could see the running time, resolution and etc etc but now the fields are completely blank.
Blank Information
Install the free MediaInfo, it places itself into the windows explorer context menu for files and provides extremely detailed info. I'm not sure what was providing the 'right click' info previously, but it is not a change in v9 AFAIK.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
