I'm curious if DVDFab can convert or work with the movie files such as those from Flixster or other types of Digital Copies downloaded legally.
I *believe* I located the file, it's 2gb in size, but does not have any extention that I can see.
What are my options, I couldnot seem to open it with CONVERTER.
Edit: I can read the file with MediaInfo, here's what it says:
General
Complete name : C:\Users\xxxxxxx\Desktop\556C1889A5373C400xxxxxxxx xxx8F
Format : MPEG-4
Codec ID : M4V
File size : 1.85 GiB
Duration : 2h 3mn
Overall bit rate mode : Variable
Overall bit rate : 2 141 Kbps
Encoded date : UTC 2012-09-18 10:25:49
Tagged date : UTC 2012-09-19 23:16:22
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 4 frames
Codec ID : encv / avc1 / mp4a
Duration : 2h 3mn
Bit rate mode : Variable
Bit rate : 1 997 Kbps
Maximum bit rate : 3 000 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.289
Stream size : 1.73 GiB (93%)
Encryption : Encrypted
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 3mn
Bit rate : 141 Kbps
Nominal bit rate : 132 Kbps
Maximum bit rate : 168 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 124 MiB (7%)
General
Format : MPEG-4
Codec ID : M4V
Duration : 2h 3mn
Video
Format : AVC
Duration : 2h 3mn
Width : 720 pixels
Height : 400 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 3mn
Bit rate : 141 Kbps
