I am looking to upgrade my system to the new Haswell I7-4770K and was after somre advice on utilising Quick Sync. Is it a must to have Lucid? Many of the 1155 motherboards had this software bundled but all the 1150 boards I have looked at so far do not. I may have to purchase it separately if it is really necessary.
Quick Sync Advice
If you're planning on adding a discrete graphics card and you are a gamer it might be a good idea. If not you don't need a graphics card at all, I've unplugged mine and just use the HD 4000 chip so I don't need it.How to post the internal log
The only thing you will gain over the 3770k is onboard gpu you can get a 1155 board and put a high end cpu + good gpu tht will out perform 4770k save u some cash too
Check out this bench mark
I love my z77 board with the 3770k
Btw the board must support QS idk if you can purchase software i belive 1150 boards dont offer lucidLast edited by Jonatan; 08-23-2013, 10:50 AM....
...Death Before Dishonor...
Originally posted by Jonatan View PostThe only thing you will gain over the 3770k is onboard gpu you can get a 1155 board and put a high end cpu + good gpu tht will out perform 4770k save u some cash too
Garry, here is a that compares the CPU to other I7s might help you choose the best one.How to post the internal log
Ye gods, I have a carpet cleanng machine that does not move as much air as their overclock setup.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Did you notice they cold bugged one of the processors at below -110°C! Must be using liquid nitrogen.How to post the internal log
Originally posted by martythebrit View PostI Like MSI boards myself, take a look at this one, it comes with Virtu;
Have you seen where they remove the heat spreader on the Haswell & Ivy Bridge CPU and replace the thermal spread and get lower and more consistant temps on YouTube? Whats up with that?
Would the 4th gene CPU's be faster than 3rd gene? I don't care about the grafhics card, just want to use QS!
Been a while, but am I highjacking, sorry if I did!
Been looking for a while for new M/B and i7 CPU, now things have been updated to a new platform, guess I'll start over!
8855A; I wouldn't worry about the heat spreader, I've never had a problem and you probably wouldn't unless you start overclocking.
The 4th generation i7's are definitely faster, but, your paying a premium for it. It's up to you to decide if that premium is worth is the extra speed.
Take a look here;
http://www.cpu-world.com/Compare/590..._i7-4770K.html
I'm not sure what you have now, earlier this year though I went from Sandy Bridge to Ivy Bridge and I'm happy with the performance gain. I decided to skip Haswell and will upgrade to Broadwell when it becomes available.
