I have tried to rip two millenium movies the last few days. The Iceman, and Killing Season. The software doesnt even recognize the discs are in there. Anyone else have this problem?
Millenium Movies
Does the drive spin up at all? You could try disabling PathPlayer before insertiing the disc. Some of the old Infinifilm discs give PathPlayer fits. Post the DVDFab internal log session from one of them.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Hi Ruikee
Please give this a read through http://www.dvdfab.com/manual/settings/PathPlayer
See pic on disabling it, just make sure to set it back to always enabled.
Hope this helps
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Fred,
Thanks for the feedback. Possibly some software conflict for the OP. ?? I know the Infinifilm problem still exists for some titles (several years old).Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
