Installer
    Installer
    I have seen this lately and don't know what I am suppose to do with it if anything.
    Installer:
    CRC32: 0187edb7
    MD5: 3eba3df346904ae90b139dffac18dce8
    SHA-1: e302e29024e3150312b6ff81fae409e611da9dab
    I have been installing updates with no problem, am I missing something ? Please explain... The above info is from DvdFab 9063, I believe it changes with each rev.
    These are checksums that allow you to verify that the DVDFab installer in question is not corrupted. This rarely happens, you do not need to do anything about it. To use the numbers, you need a utility to generate checksums from the installer file that you downloaded if it produces an error message when you try to run it.
