To further enhance our community services and improve user experience, we will be performing a comprehensive system upgrade of the DVDFab Forum on October 29, 2025 at 15:00 Beijing Time.
During this upgrade, all of your account information as well as previously posted threads and replies (Recently 12 months) will be fully migrated and preserved.
After the upgrade, you will be able to log in to the forum using your existing forum account or your DVDFab Member Center Account—no additional action is required.
lightning shrink could be enabled after setting CUDA as decoder & encoder manually.
@ Wilson Wang ,You said lightning shrink could be enabled after setting CUDA as decoder & encoder manually....And how do you do that? PLease enlighten me.If you talk about changing software to Cuda etc.that won't do it.Unless you know another way....I'm listening.
If you have the disable all gpu codecs checked you won't be able to check it as it gets grayed out but if you have it unchecked then you can check lightning shrink.You set cuda by clicking the pull downs and choosing cuda for each of the boxes so it shows in the box for each codex do it for all boxes as shrink works with cuda.
Glenns,I know all this.Everything and all of it.lol.But here is the difference between version 9.0.6.9 plus 9.0.7.0 compaired to 9.0.7.1 and 9.0.7.2 ..The square to tick for lightning shrink in 69 and 70 has dark edges and I can click on.The square in 71 and 72 edges are a bit gray "out"and won't take the tick.
In 71 & 72, "Enable Lightning-Shrink" option is disabled when using a low graphics card(such as GT520), but the lightning-shrink still could be used automatically after setting CUDA as decoder & encoder manually.
The option is enabled when using a high graphics card (such as the GT630).
But need to discuss with our dev for the issue.
Hope this help you!
Hope this help you!
Sorry, just use CUDA decoder & encoder not Lightning-Shrink.
