Well I don't know then, that's the way mine works. When I select it it grays out everything and if I disable GPU codecs that box is grayed out. Maybe a developer will drop by and enlighten us?
Enlighten us are the right words for it. Use DVD FAB since the very beginning about 200 years ago, lol.I think I should know by now what to do!!!! It was OK in version 9.0.6.9
Downloaded back to 9.0.7.0.Ticked lightning shrink and have no problem.So what's wrong with version 9.0.7.1 that I can not tick on to lightning shrink??
Bert, you are asking the impossible if you don't supply some information about your system. See my post #6 in this thread and supply that at least. A DVDFab internal log session from v 9.0.7.1 might also be helpful.
Sometimes files get corrupted take Fab off your computer download cc cleaner from the web a free trusted program it can clean old junk files from your computer and also can clean the registry do both then re download fab 9071 from the front page when it asks if you want to save your settings click yes, re start your computer when asked by Fab then recheck your settings page and try again.
I just installed v.9072 on a XP Pro - 64 bit, SP3 hdd and tried it out.
Worked exactly as my old pal 90312 described...
...hey 90...just one "old" fart to another...
I rarely boot up from the XP hdd, but happy to tinker with it if you have any ideas.
I built this rig (core i7) 4 years ago to coincide with retail release of Win 7
Geesh, 4 years already...
Good luck
