Magic jack won't run correctly when fab is running.Magic jack shows up as a drive in Fab settings and windows lists it as a drive.it doesn't matter if you check the tick box in Fab settings or not when you use magic jack while fab is running (it doesn't have to have a movie loaded in it) you get dial tone and call seems to connect but theirs no audio.
I set my device in magic jack settings as telephone and use hdmi settings for windows vista audio.If Fab is not running magic jack runs fine.Version 9 & version 8 doe's this.Magic jack doesn't appear as a separate drive in version 8 it just lists drive letters.Also their will be no voice to incoming calls when Fab is running and calls won't go to voice mail because the call goes through but theirs no audio.Once Fab is not running everything returns to normal and works fine.Seems hdmi audio is being held hostage while Fab software is running.
