Command line to batchconvert DVD-directories with ALL audio and subtitels
    Other Command line to batchconvert DVD-directories with ALL audio and subtitels
    Dear forum members,
    I am looking for a way to convert a bunch of DVD-directories to mkv using the command line for DVDfab-Ripper.
    Unfortunately I could not find an option to automatically select ALL audiotracks und types as well as ALL subtitels.
    What I am looking for ist something like:
    /AUDIO * /AUDIOTYPE *
    /SUBTITLE *
    Any ideas?
    Thanks in advance!
    Tom
    While there may be a way to do this from the command line, I think you will find the task queue in the GUI faster and, given the many setup options in Ripper, easier to configure (less prone to error).
      Go to settings and preselect Afar as audio and subtitle default. Since most likely none of your DVDs will have this track, DVDFab will rip all tracks.
      MultiShrink
      : DVD Shrink batch processing
      Offizieller Übersetzer von DVD Shrink deutsch
        Preselection
        Thanks for your answers.
        But: (and there ist always a but)
        The default language setting does not work in ripping mode...
        (Using version 9.1.1.1)
