R2 > R1 not working
    Other R2 > R1 not working
    Dallas Complete series from Amazon UK R.2
    Streams from HDD fine but when I burn a disk, it shows up error, PAL
    What am I doing wrong?
    "Remove RC" and all other boxes are ticked off
    So I just read this post
    Found that I cannot burn the disks as RF
    So now I am thinking instead on being meticulous with customizing and quality, maybe I could just back up the disks using "DVD 9" to keep full quality, is this normal to use DVD 9 for something like this since I never plan on burning the .ISO?
      DVDFab is not going to change PAL to NTSC. If your player won't play PAL discs you need another tool for conversion to NTSC.
        you can get the complete R1 dvd series here - http://www.ebay.com/itm/Dallas-The-C...item1c3a9e051c
          Thanks for the reply
          So what's the difference in backing up using DVD5 vs DVD9 for streaming only?
            DVD5 will compressed DVD size about 4300M.
            The size will compress to 8100M when using DVD9. If the disc size dose not over the size, it does not compressed.
            You also can use the clone, it copy the disc 1:1.
            DVDFab log default location:
            DVDFab Player 5:
              Great, thanks
              Difference in clone and ripping to DVD9?
                Clone copies discs bit-for-bit, in bit order. Full Disc copies in file order. Neither one allows you remove unwanted content, and Clone does not allow compression and writes only to an ISO file. For streaming, I would suggest Main Movie copy mode, since normally this is what you would want to stream (the movie itself).
