How to disable license info splash screen.
    Hi, I went through the software but may have overlooked it. Every time I launch DVDFab Copy, I get the (annoying) license info splash screen. It started when I updated to latest version (DVDFab 9.1.2.2) TIA!
    There may be a checkbox in the popup to disable it, but I do not see the popup on startup, just the normal filmstrip splash screen. Fab may show that if you have a module that is about to expire or is in trial mode, not sure.
      License info splash screen
      Hi, forest.lawn
      You are using a trial version or lincense has expired.
      Please check it !
        Well, I want to use the free/limited version and still see this "license has expired" screen which is very annoying. I just want to activate the free version and forget about it but it's not possible.
          Originally posted by lixichen View Post
          Hi, forest.lawn
          You are using a trial version or license has expired.
          Please check it !
          NO! I paid for "lifetime license" for DVDFab COPY and it shows "Activated". as far as the other listed software, I never bought or use.
          Maybe If I re-install it? The point is I have proof of purchase but This license splash screen IS annoying!! Please advise Tech ppl. TIA!
            Problem solved!!!!
            It seems activation is still needed even after an update. When I click activate(tion) the PW was missing. After inserting the PW, no more
            license Splash screen. I hope this helps someone. Thanks for the help group.
              Thanks for your sharing. It is great and helpful.
              Note:
              The live-update normally would not erase the user settings, just like download the new version and overwrite dvdfab. However, the complete uninstall would do the erasing.
              I'm not a genius, but to make every effort to do it.
              Edison
