Installing v9
    Other Installing v9
    Very simple question. Do you have to uninstall 8 before installing 9?
    No you can have both installed at the same time.
      So there will be no issue with your reg key having both then?
      Also if I can add this, I have not had to use my account in 4 years. I no longer have the same email addy and don't have the password. Any help would be great since you have to reg the new version, thanks.
        Matrix
        It is unlikely that anyone can help you with the email/password problem until the office opens on Monday (Sunday evening in the Western hemishpere). For your protection and secutiry, the license database is stored only at the office and is not accessible from any network. You will need to be able to tell them some or all of the following information 1) the approximate date of the purchase, 2) how you paid and the order number if you have it 3) what the original email address was, even if you can't access it any longer.
