mkv
    Passkey mkv
    now here is one for you guys, i keep trying to convert promethius to mkv & like maby 3 min. into the movie the audio is about 3 to 4 or 5 sec. out of sink
    (THIS IS THE ONLY MOVIE THAT DOES THIS!) very VERY frustrating. could someone please tell me what it is about this move. now it works just fine as a regular copy and burn
    Last edited by sfrcpilot; 03-02-2014, 12:17 AM. Reason: in the wrong place should be in gen. questions
    Have not seen others post about it. Since this about a specific movie, please post about it in the forum area below (Software Support) for the module you are using. We can then immediately tell if it is DVD or BD, which version of DVDFab etc. It might also speed things up if you can locate the DVDFab internal log session from the bad conversion and copy and paste it into a new text file and attach it to your new thread. You can edit the internal log with Notepad or other text editor.
      promethus mkv file
      DVDFab 8.2.3.0 (2014/02/19 05:57:23)
      0m 02.69s: Start preload dll...
      0m 02.78s: Load dll successful.
      0m 02.79s: Start load fabplay dll...
      0m 02.91s: Load fabplay dll successful.
      0m 02.91s: Windows os type is: 8.
      0m 03.21s: Transfer settings successful.
      0m 03.43s: GPUAccelerate: 0
      0m 03.43s: CUDA cap: 0
      0m 03.43s: Support coreavc decode: 0
      0m 03.43s: Graphics info: NVIDIA GeForce FX 5500 : :
      0m 03.47s: Qt Translator file load success
      0m 03.90s: Load config successful.
      0m 04.19s: Init profile data driver sucessful.
      0m 22.94s: Init GPU settings sucessful.
      0m 22.95s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
      0m 22.95s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
      0m 23.58s: Config ExBar successful.
      0m 23.58s: dvd2dvd have 4 elements.
      0m 23.77s: dvd2mobile have 29 elements.
      0m 25.59s: blu-ray2blu-ray have 0 elements.
      0m 25.59s: blu-ray2mobile have 0 elements.
      0m 25.59s: blu-ray23d have 0 elements.
      0m 25.59s: blu-ray2dvd have 0 elements.
      0m 25.59s: file2mobile have 0 elements.
      0m 25.59s: file2dvd have 0 elements.
      0m 25.59s: file2bluray have 0 elements.
      0m 27.94s: Config work ui controls successful.
      0m 28.50s: Init burn engine successful.
      0m 28.66s: StartNotify successful.
      1m 00.97s: set folder E:/MOVIES/MainMovie/PROMETHEUS 124 MIN/VIDEO_TS/ with type 0
      1m 00.97s: opening folder E:/MOVIES/MainMovie/PROMETHEUS 124 MIN/VIDEO_TS/
      1m 01.10s: pathplayer enabled
      1m 06.85s: WorkAttr::Init Start
      1m 06.97s: WorkAttr::Init OK: generic.mkv.h264.audiocopy
      2m 17.49s:
      2m 17.49s: info: create config(0)
      2m 17.49s: info: convert profile(generic.mkv.h264.audiocopy)
      2m 17.49s: info: dvd playlist(1),angle(0),chapter(1->37),3D(0)
      2m 17.49s: info: streams((480.2)(128.1))
      2m 17.51s: info: set output video frame_rate(24000/1001)
      2m 18.64s: info: h264_encode: encode param profile(1) level(30) bitrate(788)
      236m 27.34s:
      ------ finish mobile work ------
      does it on the new 9 series also
      Last edited by sfrcpilot; 03-02-2014, 07:07 AM. Reason: clicked when i should have
