Woookao
    Woookao
    where can I get the download for this Woookao
      Thread moved here.
        it say it installed but the folder is empty and no icon
          As with any installer on the web, download it to your computer and install it as administrator from the download folder. Never run from the web, that never works well and sometimes other nastiness installs along with it.
            Try it like this:
              I've never managed to install it either. Same result as you.
              Perhaps if you already have DVDPasskey installed, it's the reason or you live outside the US.
                Same here
                  When I installed it I got an empty folder too.
                    Same here
                    And you live in Woookao purpose land.
                      I think it only does anything if the user has the US version of DVDFab installed. I will check it here also.
                        Installed that US version and still an empty Woookao folder.
                          The information on this non-Fab product is limited, it is now in at least it's 3rd version and there are hints that there may be more on the website. Probably best to just accept that it works for US Fab users and not ask too many questions. I can promise you that the opponents of Fair Use are watching.
                            Woookao does work in US
                            All u have to do is restart DVDFab and it is working
                              works great for me... cant find where the program is but it works
