Weird GUI issue DVDFAB 9........
    I understand this is not supported under Linux, but I'm hoping somebody else here might be able to shed some light on this strange GUI rendering issue I'm having running DVDFab 9 under Wine on Linux Mint. I can still use the application (HD Decryter) fine, but ever since version 9 the GUI renders very strange like the image below. Intel HD Integrated graphics on the machine, no Nvidia or AMD. Any thoughts or suggestions appreciated.
    No idea if this will help but something to try:
      Thanks, I'll try it
      I will give that a try, the problem is the all dialog windows have the crazy rendering so I can't get into the settings to make that change. I do however have DVDFab also install on a windows vm. Could the tell me file where this setting is stored? If so, I can enable QT rendering in the windows vm DVD fab, and then copy that config file to my WINE installation folder for DVDFab. Thanks
      -hogfan
        Not sure if the storage for that is in an accessible file, I will check. I suspect this is a Qt problem of some sort.
          Thanks.
          Thanks for checking. I am suspecting it a QT related issue as well. The issues started with the release of DVD Fab version 9.
            Qt began in v8, but the development environment is updated periodically. Sorry you are having problems.
