DVDFab HD Decrypter
    Other DVDFab HD Decrypter
    I have a lifetime license to DVDFab Platinum, and it is successfully activated. The license screen also shows that HD Decrypter (free) is activated, but I don't know how to access the program. DVD Copy and DVD Ripper are "Never Expire", but every other function is a Trial version. When I ripped a Blu-Ray DVD, it had the annoying DVDFab bug in the upper left corner of the video.
    It's taking me a while to get used to the current user interface. It was much simpler for me in the old days.
    Hi Pat law
    If you do not have the paid version of Bluray copy then you will get the DVDFab watermark embedded in the video.
    The free HD decrypted will not be needed when doing DVDs since you have the paid version of these modules but, when you did the Bluray it kicks in to remove the encryption.
    CBR929
      Hi Pat law
      Are you saying that the watermark will always be embedded in the free version?
      Understood
      CBR929
      There is no encryption. Does "it" refer to the free version? I don't understand when the free version would be useful at this point.
      Thanks for taking the time to help me understand.
        The trial version will have the watermark in all Ripper conversions during the 30-day trial. The free version (HD Decrypter) does not include any Ripper functions. It includes only limited functionality versions of DVD Copy and Blu-ray Copy.
