I can not enter the advanced settings
advanced settings
What exactly are you trying to do? I assume you are in ripper trying to make an MP4 or some such. You must select a source before advanced settings is active.How to post the internal log
Please see 90312's advice, you can not click the button until a Source is loaded by DVDFab. Put a disc in your optical drive or select a DVD or BD folder or ISO from your hard drive. Post a screen capture of the DVDFab window if it still does not work.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
