DVDFab 9.1.7.9 (Win)
    Was using 9.1.7.6 (non-US) & was advised of an upgrade to 9.1.7.9. Tried to download from the homepage only to find that I got 9.1.7.6US (also tried a live update, but it quit @ about 99%). But, I've tried to avoid the "US" versions due to them freezing after completing a clone-DVD. Seems that the "operation complete" popup gets stuck under the main window. But anyhow, there's no 9.1.7.9 on the homepage.
    The download center is showing 9.1.7.9
      Try it again, I just downloaded it with no problems. If you are on a US IP address, you will get the US version unless there is some server or website problem.
      ///////////////UPDATE//////////////
      There is some server issue, US IP addresses are still getting v9.1.7.6. It will be corrected when the office reopens in about 11 hours.
        None
        ty Signals.
        apollo13
          Hi Apollo13 and others, sorry for the problem.
            The US download problem has been corrected, please try it again. Sorry for the inconvenience!
              Hi Team.
              I have a strange issue with trying to upgrade to 9.1.7.9
              I am in the UK and am trying to upgrade from 9.1.7.6. I download the update via download centre (as always) and once the download has completed and installed the program loads into version 9.1.7.6.
              Is there currently an issue with the download centre at the moment? I have noticed during the update process the update no longer asks for installation path and I also no longer see the files being updated, just the download centre stating updating.
              Any help would be greatly appreciated.
              Many thanks in advance.
                Originally posted by Dazmeister View Post
                Hi Team.
                i would uninstall dvdfab, restart computer and re download.
                  I'm having the same issue as Dazmeister. Once DvdFab updater popup comes up, I click update. It downloads.I close DvdFab. I hit install update and it goes through the package. Then says restart DvdFab to use new version.I restart it and it's stuck back on 9.1.7.6 again.
                  I've tried several times over the past few days with the same results. Some bug somewhere if multiple users are getting same issue.
                    This may be an updater problem, or a US version update problem. Start over by downloading the full installer manually and running it As Administrator. There are currently no known issues other than this thread and I had no problem updating with the full v9.1.7.9 installer.
                      Thanks for the info guys. I downloaded the package and updated to 9.1.7.9 fine. There must have been in issue with the auto updater as another user experienced the same issue as me.
                      Thanks again!
                        The same issue is occurring with 9.1.8.0 today
                        Mutt ... All-In-One Lifetime Member
                          Download the full package rather than use auto-update.
                            I had the same problem ... i download on website the version 9.1.8.0. I install over the current version 9.1.7.9 and the problem was resolved.
                              Thanks for the feedback Electro.
