The other week I had an issue where DVDFab stopped working and kept reporting errors with reading any disks even though earlier that day it was fine.
I reinstalled Windows as knew it was due to something being installed (but not sure what) maybe even something to do with usb drives when they get mounted and windows installs drivers for them, plus there were also some windows updates.
Well again today after successfully reading disks, I'm now back to the dreaded errors of fab not working again for any disk.
I have recently been checking some memory cards using a usb adaptor, which caused windows to install drivers and also have recently received a load of windows updates.
Just annoying that something simple can wipe-out the operation of dvdfab
this is the output of the internal log file
please ignore or delete - see on another sub-forum that other users are having this issues
Code:
DVDFab 9.2.0.2 (2015/06/12 23:25:47) 0m 00.01s: Init Public log : enabled. 0m 00.01s: Init Private log : finish. 0m 00.01s: App info: 2015-6-10 0m 00.01s: App info: 9.2.0.2 9202 Official 0m 00.02s: Init CrashReportSettings : enabled. 0m 00.02s: Init DVDInfo_Log : enabled. 0m 00.02s: Init Qt_Log : disabled. 0m 00.09s: Profile Manager :: Begin Load Profile 0m 00.10s: Qt Translator file load success 0m 00.10s: App info: client type 2. 0m 00.11s: MobilePlay load: preload successful. 0m 00.16s: MobilePlay load: Load successful. 0m 00.17s: Init process: Transfer settings successful. 0m 00.17s: info: check logpath= C:/Users/Mike/Documents/DVDFab9/Log/ 0m 00.18s: info: _check_gpu is running ... 0m 00.33s: info: check_gpu run successful 0m 00.33s: info: recommand= 56, Shrink support= 0, enable= 0, cuda_cap= 1 , cpu_count= 8 0m 00.34s: GPU check: GPUAccelerate-4159 0m 00.34s: GPU check: GPUAccelerate setting-56, 56 0m 00.34s: GPU check: CUDA cap-1 0m 00.34s: GPU check: Support coreavc decode-0 0m 00.35s: GPU check: Lighting shrink status-0, 0 0m 00.35s: GPU check: Graphics info 1: NVIDIA GeForce GTX 580 : 9.18.13.4752 : 2.0 0m 00.35s: Init process: Load config successful. 0m 00.36s: Init process: Windows os type is 64bit System Windows 8. 0m 00.36s: Init process: command line in is 0m 00.40s: Reg check: Parse string: ( 2:8260762964 )( 11:8260762964 )( 21:8260762964 )( 22:8260762964 )( 1:0 )( 20:0 )( 60:24 )( OV:9202 )( BV:9197 )( S:7b6b1199f7aabadb6f4d5218a03adabf ) 0m 00.40s: Reg check: Option check status-Local 0m 00.41s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:0:0 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:0 )-( Blu-ray to DVD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )- 0m 00.41s: App info: language type ENU. 0m 00.41s: App info: Install path C:/Program Files (x86)/DVDFab 9/ 0m 00.41s: Reg check: Start get sys number. 0m 00.41s: Export Blu-ray source information report : enabled 0m 00.41s: Reg check: Serial number is: f4-6d-04-b0-19-ad 0m 00.42s: Init process: Init GPU settings successful. 0m 00.42s: Reg check: Connect type is: 0 0m 00.42s: connect plugin info : start. 0m 00.93s: Profile Manager :: End Load Profile 0m 01.08s: connect plugin info : 1:1 0m 01.23s: Reg check: Times of connecting error is: 0 0m 01.24s: Reg check: Parse string: ( S:495c7e22dd626cc12b4a30c10cf71709 0m 01.24s: Reg check: Option check status-NewWork 0m 01.47s: Init preview: Begin init preview play engine. 0m 01.47s: Init preview: Begin init preview play engine(Internal). 0m 01.62s: Init preview: Init internal engine successful. 0m 02.03s: Burn engine: start init. 0m 02.04s: Burn engine: set log folder. 0m 02.04s: DVD: init read settings. 0m 02.04s: DVD: init write settings. 0m 02.04s: DVD: DVDInfo_SetDvdrBlocks size = 2201600 0m 02.04s: DVD: after DVDInfo_SetDvdrBlocks 0m 02.12s: DVD: after SetBurnEngine, Burn Type = 0 0m 02.12s: DVD: after init write settings. 0m 02.12s: DVD: finish init write settings. 0m 02.12s: BD: init read settings. 0m 02.13s: BD: init write settings. 0m 02.13s: bd set region B 0m 02.13s: Burn engine: config engine type-0 begin. 0m 02.13s: Burn engine: config engine type-0 end. 0m 02.13s: Burn engine: writer count 1. 0m 02.14s: Burn engine: 0- F:\ [TSSTcorp DVDWBD SH-B123L SB04 (Scsi)]. 0m 02.14s: Burn engine: end init. 0m 02.51s: Init process: Init setting page successful. 0m 02.51s: QtLog Mode = false 0m 02.52s: Show ProductsInfo Dlg 2 0m 08.73s: Show UI Step 2 0m 08.99s: Show UI Step 3 0m 08.99s: Start show MainUI. 0m 08.99s: Show QUserExperienceDlg Dlg 1 0m 11.15s: Show QUserExperienceDlg Dlg 2 0m 11.16s: UI manager: switch to Copy mode. 0m 11.94s: Init process: init main ui successful. 0m 12.19s: Plugin Info : 1 exits flag = false plugin path = C:/Program Files (x86)/DVDFab 9/Plugins\VideoDownload.xml 0m 12.19s: connect plugin info : start. 0m 12.22s: Init process: show main ui successful. 0m 12.23s: DriveX msg: Init driveX F with I/O mode: 0 0m 12.23s: opening drive F 0m 12.23s: opened i/o 0m 12.24s: got media type 15 0m 12.70s: got max lba 22073183 0m 15.42s: got disc type 20 0m 15.43s: type Blu-ray BDMV 0m 15.43s: volume label 4321_G51_SE 0m 15.44s: DriveX msg: add media in driveX F. 0m 15.44s: DriveX msg: send open media msg to thread for driveX F. 0m 15.45s: Source manager:open source flag:1,1,1,1,1 0m 15.45s: Source manager:open source flag:1,1,1,1,1 0m 15.46s: Source manager: add source id 0. 0m 15.47s: bd set region ? 0m 15.47s: Source open status:DVD Yes, 2231-10-11 0m 15.47s: Source open status:BD Yes, 2231-10-11 0m 15.47s: bd set region ? 0m 15.48s: internal path F:/BDMV/ 0m 15.49s: aacs 1 bd+ 0 0m 15.81s: got bdmv 0m 16.90s: movie name: 4.3.2.1||4321_g51_se 0m 16.90s: got agid 0 0m 16.97s: sent host cert chal 0m 16.97s: got drive cert chal 0m 16.98s: BEC 1 0m 16.98s: DRIVE_VENDOR 0x0182 0m 17.06s: got drive key 0m 17.06s: got host key signature 0m 17.07s: verified drive signature 0m 17.07s: verified host signature 0m 17.15s: sent host signature and key point 0m 17.16s: got bus key 0m 19.53s: got volume id 0m 19.53s: got volume id mac 0m 19.54s: volume id is correct 0m 19.55s: got vid 0m 19.71s: blu-ray A05965721D74D50DAE56AA996CA7445FD9B35783 0m 20.27s: cert BEE=0x00 same 0m 41.83s: mk exception 0m 41.84s: failed to open 306 0m 45.52s: Source manager: open failed, delete source id 0. 0m 45.52s: Source manager:open source flag:1,1,1,1,1
