Unsure how to update current software version 8.2.2.3 for current titles like Kingsman and Taken 3. Can anyone steer me in the right direction. Any help will be appreciated, Thanks in advance.
Stupid Question ?
You will need to make the transition to v9, v8 does not support these titles and is not likely to be updated. Your DVDFab license is fully valid for v9 at no charge, but you will need to create an account at the Member Center on the DVDFab website using the same email address that was used for v8 registration. You then enter the email address and password from the Member Center into DVDFab v9 after installing.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
