Keep getting errors with Imgburn
    Other Keep getting errors with Imgburn
    When I try to burn using Imgburn I keep getting errors with it but burns okay with vso & fab burn engine
    Paid Not To Work
    US Navy Retired ( 20 Years )
    Proudly Served On
    USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
    6 trips to the Gulf Of Tonkin
    Jimbo--
    Do the errors show up on playback of the disc or are you getting some sort of error code or message from Img? Need more info to try to duplicate it.
      Also, are you burning from withing DVDFab or externally by running the program yourself?
      I only use ImgBurn manually and have never had an issue burning the results of DVDFab.
        I will send the error from imgburn the next time I try to burn with it, Mr. Video I am using it within dvdfab
        Paid Not To Work
        Proudly Served On
          Then try using it standalone. Run DVDFab and when it is done, run ImgBurn.
