Setting for multiple files
    Hi, just a quick question. Not able to figure out how to do this, or if it is even possible...
    Lets say I have multiple video clips and I drag and drop them to DVDFab convertor. Is there a way to apply one settings (ie: video/audio resolution and bitrate) to all files in one go, or do I have to do this separately for each files.
    Thanks, Monty.
    Have you tried saving a default format with the audio bitrate and video bitrate just as you want it?
      monty
      Due to the way frame rate, frame size, bitrate and bits/pixel interact this is impractical unless all the source clips in a given batch have the similar characteristics for video (and audio type also to a lesser extent). The defaulting will work but may not produce optimum results.
