What is the correct method to move/install DVD Copy or Ripper V9 and activate on a new system?
Activate on new system
1) Uninstall it on the old system
2) Download the full installer to the new system, run it As Administrator
3) Activate your installation by opening DVDFab with no discs and using the steps shown in the capture. You will be asked to enter the email address and password you used to set up your account in the Member Center.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
