DVDFab No Longer Loads
    have you checked to see if your graphics card drivers
    are up to date or if they are try rolling back to an earlier driver.
    My ATI Radeon 4650 is up to date
      Once again I did a complete uninstall and a re-install only to get the same results. DVDFab loads between 136000 and 137000 and then it stops responding. Below are the 2 log files from this installation.
        wouldn't think that your antivirus sofware may be preventing dvdfab from
        trying to start would it ??
          That was one of the 1st things I disabled.
            siginals, Is anyone still looking into this?
              see if dvdfab will run in "safe mode"
                Originally posted by j427982 View Post
                I have not changed the way I run dvdfab. It has worked for years. I believe I am running it as administrator. I just tried right clicking and clicked run as administrator and it still gets to a point and then stops responding.
                Could try this - if you download the installation .exe file and the in Windows Explorer right click on the installtion file and select run as Admin and the let it install.
