I have a lifetime on all products. The NAG Screen to register continues to appear after update 9.2.2.4, the option to disable is gone. Tried uninstall (complete) then re-install, manual registry clean, no luck. This problem is not critical but annoying! Thanks for an otherwise very nice suite!
License Nag Screen
Did you activate your licenses? What is reported on the License Info screen (don't post it here)?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Update to the latest beta and maybe it won't do it?How to post the internal log
Please do this: click the Buy link and see what it tries to sell you. Then see if that is on your list in the Member Center. Sounds like something is in Trial mode. If you are positive that you have a license for everything, just click Activate to re-register everything. A file may be corrupted. Activate will force it to get new authorizations from the server.
If none of that works, send me a PM and I will ask you to upload some things.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Signals, Thanks for the reply. When I click Buy it brings me to the Hone/order screen of the website with all products displayed for purchase. I re-activated everything and still get the nag screen. All the products work but it is annoying. Thanks for any help you can offer. I can e-mail you screenshots or logs if that might be useful. Thanks again!
This is a very unusual problem. I will send you a link and instructions by PM to upload some things.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
