i was reading about your cinavia tool at
i downloaded the 5min audio. i listened to it.
it appears that they have been lying to us, in that,
the changes they introduce to the source for cinavia are distinctly audible.
question 1) am i missing something? is it distinctly audible?
that brings me to question 2+.
if there is that much of a difference to the audio, then if we made a copy
with cinavia in the program material and played it on a player that does NOT
recognize cinavia and it (obviously plays through) then wouldn't that audio
be degraded? does a play that recognizes cinavia and has the ORIGINAL
disk in the machine (obviously plays through) produce different sound?
do those players process that sound back to the original similar to what you are doing?
if they do NOT process the sound, then the ORIGINAL DISK and COPIES
on any machine that will play it, should be the identical when played.
if that's the case then you are changing the sound from what we have now on our ORIGINALS and COPIES to what, YOU think is the ORIGINAL MASTER
was before cinavia was introduced to the released audio.
am i correct?
to summarize, if they have lied to us, and cinavia was distinct audible,
and no players processed to audio back to the original source when outputting, then all the disks (ORIGINALS, COPIES, everywhere are
going to sound different than the new regenerated version from your new tool.
what am i missing here?
jetli
am i correct?
jetli
