Hi Folks,
Just purchased myself DVDfab today and after some initial hiccups I can safely say I'm pretty happy with it. I have however a few issues that I hope someone could help with.
I tried to backup 'Minions 3D' today and had to shutdown AnyDVD-HD because DVDfab complained about it. After inserting the movie DVDfab only displayed the french audio selection and no others. I then restarted Anydvd-HD and voila, all the languages were available. I was forced to keep it running in the background because of this language issue. It just seems as if AnyDVD-HD does a slight better job of analysing the disc than DVDfab.
Another issue I discovered is although I don't get CUDA crashes like I got when I tried other earlier versions, The fps speed is not as fast as it used to be. I have all settings enabled and it seldom goes over 40fps (sometimes dipping as low as 27fps). It's as if CUDA says its enabled but not really working correctly. I have an i5-3570K and GTX770 (Asus P8Z77-V motherboard with 8gb). It's a nice little system and quite snappy for games and other uses, but I cannot fathom why the older versions/trials of DVDfab seemed slightly quicker. Could it be the Nvidia drivers I am using (v361.75)? I just hope I don't have to keep uninstalling and installing older versions just to improve things.
I am also saving all backups to my Samsung 256gb SDD drive, so no problems with a slow drive.
Any help appreciated!
