MockingJay doesn't run
    Passkey MockingJay doesn't run
    I am having a problem with MockingJay part 2. Here is the log file:
    What am I doing wrong?
    DVDFabPasskey 8.2.6.6 (2016/03/26 06:49:10)
    0m 04.88s: opening drive K
    0m 04.88s: opened i/o
    0m 04.88s: got media type 15
    0m 05.36s: got max lba 12953759
    0m 06.24s: got disc type 20
    0m 06.24s: type Blu-ray BDMV
    0m 06.24s: volume label MOCKINGJAY_2
    0m 06.24s: bd set region ?
    0m 06.25s: internal path K:/BDMV/
    0m 06.48s: aacs 1 bd+ 0
    0m 06.84s: got bdmv
    0m 11.23s: got agid 0
    0m 11.24s: sent host cert chal
    0m 11.24s: got drive cert chal
    0m 11.24s: BEC 1
    0m 11.24s: DRIVE_VENDOR 0x0074
    0m 11.26s: got drive key
    0m 11.38s: got host key signature
    0m 11.38s: verified drive signature
    0m 11.38s: verified host signature
    0m 11.40s: sent host signature and key point
    0m 11.40s: got bus key
    0m 11.40s: got volume id
    0m 11.40s: got volume id mac
    0m 11.40s: volume id is correct
    0m 11.40s: got vid
    0m 11.51s: blu-ray DFBB8843538F3EE57E8E473540A30881F8A0D3A5
    0m 11.99s: cert BEE=0x80 same
    0m 12.37s: D A0B0CF58
    0m 12.37s: main playlist 00821.mpls
    0m 12.37s: selected region A
    0m 12.37s: bd set region A
    0m 12.37s: detected cinavia
    0m 12.37s: got vuk
    0m 12.38s: got agid 0
    0m 12.40s: sent host cert chal
    0m 12.40s: got drive cert chal
    0m 12.40s: BEC 1
    0m 12.40s: DRIVE_VENDOR 0x0074
    0m 12.40s: AACS bus encryption is enabled
    0m 12.41s: got drive key
    0m 12.41s: got host key signature
    0m 12.41s: verified drive signature
    0m 12.41s: verified host signature
    0m 12.44s: sent host signature and key point
    0m 12.44s: got bus key
    0m 12.44s: got data key
    0m 12.44s: got unit key 4
    0m 12.44s: blupath: movie disc
    0m 13.29s: StealthyClone with BluPath
    0m 14.55s: Java protection is removed by StealthyClone anti-protection.
    0m 14.55s: full disc copy/play may not be supported yet: 45 or blupath failed to check that
    0m 14.96s: got bdmv
    You have a version of the disc that is not supported yet (single disc version). They are working on it. Please 1) post in the Passkey forum 2) attach the log file rather than posting it as text next time. Instructions linked in my sig, below.
