9.2.3.7 Startup Time
    Even though Fab won't start for me, I'll try to navigate the install folders and locate the file. I'll try that tonight when I get home from work and post it (if I'm successful locating it).
    Thanks.
      Well, I must have a gremlin in my computer - v9.2.3.7 started right up this time. After repeated attempts with nothing but failures to load over the weekend - it decided to load tonight. Go figure... I'll continue to monitor...
        @CBR929
        Since v9.2.3.7 decided to cooperate tonight, I went ahead and grabbed the log of the latest session in case you were still interested in viewing it.
          I fixed the problem uninstalling and reinstalling latest beta
            Well, it came back with installation of 9.2.3.8
              try clicking start - computer - right click C drive - properties - tools -
              error checking - check both boxes and restart computer and let it run.
              also try doing a disc cleanup and disc defrag.
                It had nothinhg to do with drive errors or fragmented disc. I defrag the drive weekly. Also if I made a fresh install of dvdfab it fixes the problem. THe problem comes if I made a update over a older installation.
