Preview in 9.3.0.2 no longer works
    Hello.
    I installed the new version 9.3.0.2. And since then the preview no longer works. More specifically it shows a black screen. The window opens, sound is available, it seems, that the movie is played. But only with black screen.
    I use Dvdfab on a 64 Bit Windows 7 installation. For preview the internal decoder is selected.
    There are two easy workarounds for this problem, which is being corrected:
    1) Using the Internal preview engine, after starting playback, grab and move the Preview window and move it left or right, up or down. Even a slight movement should make the video appear.
    2) Choose the DXVA option for Preview in Common Settings
      Thanks for your reply.
      The first workaround it is. Moving the preview window lures the movie from hiding.
      The secoend option does'nt work here. If DXVA option is chosen, Dvdfab crashes immediately by pressing any preview button.
        Thanks for the feedback on DXVA, that worked for me with Win7 64 and DirectX 11. Hopefully an upcoming release will correct it, it is a known issue for the devs.
          I'm using Windows 10 and also had the DXVA crash. I didn't know about dragging the window yet, but I fixed it by using direct show without hardware acceleration. And that works for me.
            Update to 9.3.0.3 preview is fixed.
              Using version 9.3.1.2 and still no video. May be a compatibility problem with Radeon graphics card. Switching to Microsoft Basic Display driver allows video in preview but disables my HDMI connection.
