This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
- Fixed the OpenGL problem.
- Fixed the problem that DVDFab failed to convert on Windows Vista.
Please install the new test version and tell me the result. Thanks.
****Not need to copy the opengl32sw.dll to DVDFab 9 installation any more.
Please tell me the details for your problem if you still have the problem. please also post the new DVDFab qt internal log file here (please run Qt log from DVDFab installation, see the attached screenshot).
I'm using Vista on a 32-bit PC and the new fix did not work for me.
Also when I clicked on the "QTLog" in my DVDFab folder, it did nothing. Am I missing something?
did you try restarting your computer ??
and make sure that you are running dvdfab "as administrator".
I restarted my computer and opened DVDFab as an administrator and still no success.
I also tried running the QT Log as an administrator and nothing happened.
For 2 years I've never experienced any major problems with DVDFab until this last update. If we can't come up with a fix--would it be possible to go back to an older version?
When testing this, is it necessary to remove "opengl32sw.dll" from the installation folder? Or, does it matter?
The answer to this problem may be going back to the 9.2.4.4 version programming code and leaving the xp support in for now, as a couple others have suggested. The next version will tell hopefully.
Do you know how to roll back to the 9.2.4.4 version?
It seems as if "opengl32sw.dll" is still needed in the installation folder. I posed the question in an above post. I just updated to v9.3.0.4 and w/o this DLL it did not work.
