DVDFab Forum - Hardware Acceleration in DVDFab~UPDATED 6 May 2017
This is a sticky topic.
  • #31
    No Cuda on 2 Pass High Quality Rip
    Just wondering why I can't use Cuda on 2 Pass ripping with my Windows 10 pc with an Nvidia GTX 1060 6gb video card?
    As soon as I choose 2 Pass High Quality under H265 MKV Default Profile, DVDFab tells me it will use Software Only.
    It will use Cuda if I choose 1 Pass but I prefer the quality that 2 Pass gives me.
    My GPU's Cuda Cap number is 6.1 which is above the 5.0 required for H265.
    Though I don't see the GTX 1060 listed in the first post.
    Is this card not supported yet?
    Or am I missing some setting?
    • #32
      FQs19,
      Your 1060 should be fully supported with the correct driver. You need to supply the DVDFab internal log session and the FabCheck log so we can see what is going on here. Please isolate these sessions and attach them to a post. Instructions linked in my sig, below.
      Supplying DVDFab Logs in the Forum ...........................User Manual for DVDFab v10 (pdf)................................ Guide: Using Images in Posts
      • #33
        Update: 2-pass is not supported for encoding h264 or 265 with CUDA.
        • #34
          FQs19,
          Strange since 3dman7 says earlier that he was able to get 2 Pass Cuda working but with a bug or maybe he meant that a bug allowed him to do a 2 Pass Cuda.
          Either way, do you know if DVDFab will ever support 2 Pass Cuda ripping?
          • #35
            My information comes direct from Beijing as of today. The future of this is not currently known, they may be waiting for a driver or SDK update from nvidia. I personally don't use 2-pass any longer.
            • #36
              Thanks for the information.
              • #37
                The bug and the log files show it also.
                • #38
                  Looks more like the CPU is doing all the work, not the GPU. FQs19, follow the advice you choose. This has gone on long enough.
