Divergent allegiant
    Divergent allegiant
    Does anyone know if alllegiant region 1 works fine after putting through fab. All previous movies of this series have had the titles in the wrong order. Just wondering if I should wait to do mine. Thanks
    9.3.0.6 beta works, full disc dvd, registered version pathplayer set to always enabled, Disc plays perfect.
      Divergent Series: Allegiant
      I am getting a read error during ripping. Region 1, 9.3.0.6
      DVDFab 9.3.0.6 (2016/07/12 21:17:02)
      0m 00.03s: Init Public log : enabled.
      0m 00.03s: Init Private log : finish.
      0m 00.03s: App info: 2016-7-7
      0m 00.03s: App info: 9.3.0.6 9306 Beta
      0m 00.07s: Init CrashReportSettings : enabled.
      0m 00.07s: Init DVDInfo_Log : enabled.
      0m 00.07s: Init Qt_Log : disabled.
      0m 00.14s: Profile Manager :: Begin Load Profile
      0m 00.14s: Qt Translator file load success
      0m 00.14s: App info: client type 2.
      0m 00.17s: MobilePlay load: preload successful.
      0m 00.23s: MobilePlay load: Load successful.
      0m 00.23s: set code page : .0
      0m 00.23s: Init process: Transfer settings successful.
      0m 00.23s: info: check logpath= C:/Users/Tony/Documents/DVDFab9/Log/
      0m 00.25s: info: _check_gpu is running ...
      0m 00.93s: Profile Manager :: End Load Profile
      0m 01.32s: info: check_gpu run successful
      0m 01.32s: info: recommand= 851968, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 4
      0m 01.32s: GPU check: GPUAccelerate-0XD0005
      0m 01.32s: GPU check: GPUAccelerate setting-0XD0000, 0XD0000
      0m 01.32s: GPU check: CUDA cap-0X0
      0m 01.33s: GPU check: Support coreavc decode-0
      0m 01.33s: GPU check: Lighting shrink status-1, 1
      0m 01.33s: GPU check: Graphics info 1: Intel(R) HD Graphics : 9.17.10.4229 : 4,2
      0m 01.33s: Init process: Load config successful.
      0m 01.33s: Init process: Windows os type is 64bit System Windows 8.
      0m 01.33s: Init process: command line in is
      0m 01.40s: Reg check: Option check status-Failed
      0m 01.40s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:0:0 )-( DVD to Mobile:0:0 )-( Blu-ray to Blu-ray:0:0 )-( Blu-ray to Mobile:0:0 )-( File to Mobile:0:0 )-( Blu-ray to DVD:0:0 )-( DVD to Blu-ray:0:0 )-( File to DVD:0:0 )-( File to Blu-ray:0:0 )-( File Mover:1:0 )-( Blu-ray to 3D:0:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:0:0 )-
      0m 01.40s: App info: language type ENU.
      0m 01.40s: App info: Install path C:/Program Files (x86)/DVDFab 9/
      0m 01.75s: Reg check: Times of cinavia connecting error is: 0
      0m 01.75s: Reg check: Start get sys number.
      0m 01.75s: Reg check: Serial number is: e0-69-95-5c-28-11:ec-08-6b-69-ea-4f:1e-08-6b-69-ea-4f
      0m 01.75s: Reg check: Connect type is: 0
      0m 02.41s: Reg check: Times of connecting error is: 0
      0m 02.41s: Reg check: Parse string: ( 2:1472045871 )( 1:30 )( OV:9305 )( BV:9306 )( S:d397d0452d5f63dbfcfb01f5bbcb7a22
      0m 02.43s: Reg check: thread exit normal.
      0m 02.55s: Reg check: Option check status-NewWork
      0m 02.55s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:0 )-( Blu-ray to Blu-ray:1:0 )-( Blu-ray to Mobile:1:0 )-( File to Mobile:1:0 )-( Blu-ray to DVD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:0 )-
      0m 02.57s: Reg check: connect successful and result code is 1.
      0m 02.57s: Reg check: End check info.
      0m 02.57s: Export Blu-ray source information report : enabled
      0m 02.57s: Init process: Init GPU settings successful.
      0m 02.57s: connect plugin info : start.
      0m 02.97s: connect plugin info : 1:1
      0m 04.43s: Init preview: Begin init preview play engine.
      0m 04.43s: Init preview: Begin init preview play engine(Internal).
      0m 04.56s: Init preview: Init internal engine successful.
      0m 05.27s: Burn engine: start init.
      0m 05.28s: Burn engine: set log folder.
      0m 05.28s: DVD: init read settings.
      0m 05.28s: DVD: init write settings.
      0m 05.40s: BD: init read settings.
      0m 05.40s: BD: init write settings.
      0m 05.40s: bd set region A
      0m 05.41s: Burn engine: config engine type-0 begin.
      0m 05.41s: Burn engine: config engine type-0 end.
      0m 05.41s: Burn engine: writer count 1.
      0m 05.41s: Burn engine: 0- D:\ [TSSTcorp CDDVDW SH-224DB SB01 (Scsi)].
      0m 05.41s: Burn engine: end init.
      0m 06.02s: Init process: Init setting page successful.
      0m 06.02s: QtLog Mode = false
      0m 06.02s: Show ProductsInfo Dlg 2
      0m 37.67s: Show UI Step 3
      0m 37.67s: Start show MainUI.
      0m 37.67s: UI manager: switch to Copy mode.
      0m 38.41s: Init process: init main ui successful.
      0m 38.77s: Init process: show main ui successful.
      0m 38.78s: DriveX msg: Init driveX D with I/O mode: 0
      0m 38.79s: opening drive D
      0m 38.80s: opened i/o
      0m 38.80s: got media type 5
      0m 39.79s: got max lba 2201471
      0m 39.79s: got disc type 10
      0m 39.85s: type DVD-VIDEO
      0m 39.85s: volume label ALLEGIANT
      0m 39.85s: DriveX msg: add media in driveX D.
      0m 39.85s: DriveX msg: send open media msg to thread for driveX D.
      0m 39.85s: Source managerpen source flag:1,1,1,1,1
      0m 39.86s: Source manager: add source id 0.
      0m 39.87s: Source open statusVD Yes, 2016-8-24
      0m 39.87s: Source open status:BD Yes, 2158-1-1
      0m 39.87s: internal path D:/VIDEO_TS/
      0m 39.88s: got copyright 0 0
      0m 40.42s: got udf/iso
      0m 42.95s: got discinfo
      0m 42.96s: pathplayer enabled
      1m 19.61s: read error: 0 0 0 186762 0 0 0
      2m 00.65s: got dvdinfo
      2m 00.65s: opened dvd
      2m 02.00s: Source manager: open successful.
      2m 02.85s: Work manager: create DVD fulldisc work 0 with source 0 and uiinfo 0.
      2m 03.31s: Source managerpen source flag:1,1,1,1,1
      65m 14.41s: DriveX msg: remove media in driveX D.
      65m 14.51s: Source managerpen source flag:1,1,1,1,1
        How about main movie blu ray
          Try it yourself dbagger. Attach the log if it does not work. This thread is about the DVD, not the Blu-ray. Post in the Blu-ray Copy forum.
            jetmman
            Please attach the log session in the future (instructions in my sig), and post in the DVD Copy forum if you are having a problem with a specific DVD.
            Several entries indicate that your drive is not reading the disc correctly. Try cleaning out the drive and the disc itself as well.
              I thought it was a general question
                It is a specific question about a specific disc. Support for new java protections on Allegiant BD were added with v9.3.0.7, try it.
                  All of the 9.3's produce this black screen problem. So I won't know
                    So I installed9307 and the black screen was there. I closed the program and opened it right back up and it was fine. I don't want to close it again because I'll probably get the black screen again. Any ideas
                      jetmman
                      Thanks Signals, Cleaning the disc solved the problem. I would appreciate if you could advise how I clean out the drive. I have never done that.
                        You could buy a laser lens cleaning disc or use a can of compressed air. But spray it LIGHTLY!
                          I use the spray can of compressed air also, you can also use a DRY Q-tip or other cotton swab very very gently on the laser lenses, but NO WINDEX or other liquid cleaners, they can leave a residue that defocuses the light.
