Converting a TV Series on DVD
    I would like to convert my TV Series on DVD to individual Episodes on my DLNA Server. Is this a 2 step process of copying the DVD and then converting each episode individually or can this be done in one batch step?
    Any help/guidance would be appreciated.
    Thanks,
    Yes, DVDFab can convert it in one step using the DVD Ripper module. They will be individual files normally, but you can use the Merge function to make one large file (in a second step) if you prefer.
    If the original DVD has one large title that contains all the episodes, you can convert that in one step.
