I am Wrath
    I am Wrath
    DVD 9 ,XP with or without pathfinder enabled can not read disc correctly.Reads it as 1:24 min , and will not start properly.
    Any suggestions?
    Thanks
    Read here post #1 - http://forum.dvdfab.cn/showthread.php?t=29595
      I am Wrath
      Does this also mean , that as a last resort, I can no longer make a Clone using FAB 9.2.4.4 , that works?
      I tried using the FAB version above ,and the clone would not start the movie from the front menu.
        I used Dvdfab Windows for XP 9244 to backup the same BD into iso yesterday. It worked! I could play it using my Dune HD D1 player using full menu.
          If you need help with this, post the problem in the correct forum, in this case either DVD Copy of Blu-ray Copy and include the DVDFab internal log session. There is no way to tell from these posts what you are trying to do. v9.2.4.4 will be available for those with OS issues and will still be updated, just not as often as the regular releases.
            For now, you can use DVDFab v93xx to copy this disc without problem.
            But you are using XP, which means you can only use DVDFab v92xx
            We can only update DVDFab v92xx for XP from time to time, due to lacking of resources, sorry.
            http://www.dvdfab.cn
              I am Wrath, The Trust and all Lionsgate dvds
              This menu loop problem seems to be related to Lionsgate releases.
              Don't you feel it might be one of those time, since FAB 9.2.4.4 was released in May 24,16 to update this , XP OS problem with these discs?
                DVDBOB,
                If you need the updates faster, maybe you should consider updating your OS. The terms of this are clear, to have the same update schedule would require that resources be taken away from fixes and features for the majority of DVDFab users.
