Hacksaw Ridge StealthyClone or so called 'Screen Pass-protected discs'
    Performance Hacksaw Ridge StealthyClone or so called 'Screen Pass-protected discs'
    I just did a full disc bluray copy of Hackaw Ridge using both V9 and V10 and the times the movie is all out of sequence. I thought that DVDFAB has this StealthyClone feature where it fixes this type of 'screen pass protection' ?
    I also got the same problem with expendables 2 as well. and a while back with Allegiant.
    so is this fixable? thanks!
    Please attach the DVDFab internal log session generated by this disc.
      here it is:
      DVDFab 9.3.2.1 (2017/03/11 12:32:58)
      0m 00.19s: Init Public log : enabled.
      0m 00.19s: Init Private log : finish.
      0m 00.19s: App info: 2016-11-8
      0m 00.19s: App info: 9.3.2.1 9321 Official
      0m 00.22s: Init CrashReportSettings : enabled.
      0m 00.22s: Init DVDInfo_Log : enabled.
      0m 00.22s: Init Qt_Log : disabled.
      0m 00.22s: --- 3D implement select : Use default implement ---
      0m 00.77s: Profile Manager :: Begin Load Profile
      0m 00.78s: Qt Translator file load success
      0m 00.78s: App info: client type 2.
      0m 00.89s: MobilePlay load: preload successful.
      0m 01.25s: MobilePlay load: Load successful.
      0m 01.26s: set code page : .0
      0m 01.26s: Init process: Transfer settings successful.
      0m 01.26s: info: check logpath= C:/Users/sammy/Documents/DVDFab9/Log/
      0m 01.33s: info: _check_gpu is running ...
      0m 02.51s: info: check_gpu run successful
      0m 02.52s: info: recommand= 0, Shrink support= 0, enable= 0, cuda_cap= 0 , cpu_count= 8
      0m 02.52s: GPU check: GPUAccelerate-0X7
      0m 02.52s: GPU check: GPUAccelerate setting-0X0, 0X0
      0m 02.52s: GPU check: CUDA cap-0X0
      0m 02.52s: GPU check: Support coreavc decode-0
      0m 02.52s: GPU check: Lighting shrink status-0, 0
      0m 02.52s: GPU check: Graphics info 1: AMD (ATI) FirePro M4000 (FireGL V) Mobility Pro Graphics : 9.10.0.0 :
      0m 02.54s: Init process: Load config successful.
      0m 02.56s: Init process: Windows os type is 64bit System Windows 7.
      0m 02.56s: Init process: command line in is
      0m 02.90s: Reg check: Parse string: ( 2:8260762964 )( 11:8260762964 )( 20:8260762964 )( 50:8260762964 )( 80:8260762964 )( 21:8260762964 )( 22:8260762964 )( 60:8260762964 )( 70:8260762964 )( 61:8260762964 )( 62:8260762964 )( 200:8260762964 )( 1:0 )( OV:9322 )( BV:9320 )( S:98b0b34988b10172932c58df34b75a86 )
      0m 02.93s: Reg check: Option check status-Local
      0m 02.93s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:1 )-( Blu-ray to DVD:1:1 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:1 )-( File to Blu-ray:1:1 )-( File Mover:1:1 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:1 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:0 )-
      0m 02.93s: App info: language type ENU.
      0m 02.93s: App info: Install path C:/Program Files (x86)/DVDFab 9/
      0m 02.93s: Init process: Set account info to DriveX.
      0m 02.93s: Export Blu-ray source information report : enabled
      0m 02.94s: Init process: Init GPU settings successful.
      0m 02.99s: connect plugin info : start.
      0m 03.67s: Reg check: Times of cinavia connecting error is: 0
      0m 03.67s: Reg check: Start get sys number.
      0m 03.68s: Reg check: Serial number is: 54-79-f1-9a-ce-11:20-68-9d-5f-e3-2a:a4-17-31-4f-49-ab
      0m 03.70s: Reg check: Connect type is: 0
      0m 04.39s: connect plugin info : 1:1
      0m 04.71s: Reg check: Times of connecting error is: 0
      0m 04.71s: Reg check: Parse string: ( S:82264608c3c4e3c50a172fb67fc09d04
      0m 04.73s: Reg check: Option check status-NewWork
      0m 06.38s: Profile Manager :: End Load Profile
      0m 06.60s: Init preview: Begin init preview play engine.
      0m 06.60s: Init preview: Begin init preview play engine(Internal).
      0m 07.70s: Init preview: Init internal engine successful.
      0m 10.22s: Burn engine: start init.
      0m 10.22s: Burn engine: set log folder.
      0m 10.22s: DVD: init read settings.
      0m 10.22s: DVD: init write settings.
      0m 10.57s: BD: init read settings.
      0m 10.57s: BD: init write settings.
      0m 10.57s: bd set region A
      0m 10.57s: Burn engine: config engine type-0 begin.
      0m 10.59s: Burn engine: config engine type-0 end.
      0m 10.59s: Burn engine: writer count 1.
      0m 10.59s: Burn engine: 0- E:\ [hp BD-ROM BDCTD03HA 1.00 (Usb)].
      0m 10.60s: Burn engine: end init.
      0m 12.51s: Init process: Init setting page successful.
      0m 12.52s: QtLog Mode = false
      0m 14.21s: Show UI Step 3
      0m 14.21s: Start show MainUI.
      0m 14.23s: UI manager: switch to Copy mode.
      0m 18.59s: Init process: init main ui successful.
      0m 20.42s: Init process: show main ui successful.
      0m 20.43s: DriveX msg: Init driveX E with I/O mode: 0
      0m 20.45s: opening drive E
      0m 20.46s: opened i/o
      0m 20.48s: got media type 15
      0m 21.28s: got max lba 20436319
      0m 22.44s: got disc type 20
      0m 22.44s: type Blu-ray BDMV
      0m 22.44s: volume label HACKSAW_RIDGE
      0m 22.45s: DriveX msg: add media in driveX E.
      0m 22.46s: DriveX msg: send open media msg to thread for driveX E.
      0m 28.57s: opening drive E
      0m 28.57s: opened i/o
      0m 28.58s: got media type 15
      0m 28.98s: got max lba 20436319
      0m 30.18s: got disc type 20
      0m 30.18s: type Blu-ray BDMV
      0m 30.18s: volume label HACKSAW_RIDGE
      0m 30.18s: Source managerpen source flag:1,1,1,1,1
      0m 30.24s: Source manager: add source id 0.
      0m 30.25s: bd set region ?
      0m 30.26s: Source open statusVD Yes, 2231-10-11
      0m 30.26s: Source open status:BD Yes, 2231-10-11
      0m 30.26s: bd set region ?
      0m 30.26s: internal path E:/BDMV/
      0m 31.82s: aacs 1 bd+ 0
      0m 32.72s: got bdmv
      0m 32.77s: got agid 0
      0m 32.86s: sent host cert chal
      0m 32.87s: got drive cert chal
      0m 32.88s: BEC 0
      0m 32.88s: DRIVE_VENDOR 0x0103
      0m 32.94s: got drive key
      0m 34.61s: got host key signature
      0m 34.61s: verified drive signature
      0m 34.64s: verified host signature
      0m 34.71s: sent host signature and key point
      0m 34.71s: got bus key
      0m 35.08s: got volume id
      0m 35.08s: got volume id mac
      0m 35.08s: volume id is correct
      0m 35.09s: got vid
      0m 35.36s: blu-ray C44E088DE6E5E51B3DBA15692DBE2BEEC3BF418D
      0m 35.89s: cert BEE=0x80 same
      0m 36.79s: D 24A6C149
      0m 36.80s: main playlist 00760.mpls
      0m 36.82s: selected region A
      0m 36.82s: bd set region A
      0m 36.84s: detected cinavia
      0m 36.84s: got vuk
      0m 37.12s: got unit key 4
      0m 38.17s: StealthyClone with BluPath
      0m 42.40s: got bdmv
      1m 09.64s: got extended bdinfo
      1m 09.64s: opened blu-ray
      1m 10.10s: Cinavia : no cinavia repair data.
      1m 41.35s: Meta : the ownership is E_Meta_Is_Not_Owner.
      1m 41.36s: Source manager: open successful.
      1m 42.00s: Meta : editable flag is META_INFO_EDITABLE_FLAG_NONE
      1m 42.36s: Meta : Load meta info data from server.
      1m 52.68s: Work manager: create BD fulldisc work 0 with source 0 and uiinfo 0.
      1m 53.21s: bd-fulldisk : FillWorkData not rmove audio
      1m 53.22s: bd-fulldisk : FillWorkData not rmove audio
      1m 53.39s: bd-fulldisk : FillWorkData not rmove audio
      1m 53.40s: bd-fulldisk : FillWorkData not rmove audio
      1m 53.60s: bd-fulldisk : FillWorkData not rmove audio
      1m 53.74s: bd-fulldisk : FillWorkData not rmove audio
      1m 54.71s: Source managerpen source flag:1,1,1,1,1
      2m 31.60s: UILog:OnMsgToolbar_Start
      2m 31.61s: UILog:Msg Start : ready start
      2m 31.61s: UILog:Msg Start : start test run work
      2m 31.61s: UILog:right button to null, work falg = -1
      2m 31.75s: UILog:Msg Start : run work
      2m 31.75s: UILog:Run current Work.
      2m 32.24s: UILog:Begin work copy or converter.
      2m 32.62s: UILog:start running at thread.
      2m 32.63s: UILog:return flag at start running at thread ok.
      2m 33.04s: bd-fulldisk : FillWorkData not rmove audio
      2m 33.76s: BD FullDisc watermark flag: 0
      2m 33.76s: UILog:MsgWork:WorkStatus_Start
      2m 33.76s: bd-fulldisk : RunTask 0 audios
      2m 33.95s: Blu-ray Copy: Full Disc
      2m 33.95s: Source: E:/BDMV/
      2m 33.95s: SourceSize: 39884 MB
      2m 33.95s: RemoveHDAudio: 0
      2m 33.95s: OutputSize: 46100 MB
      2m 33.95s: OtherSize (CLPI, JAR, etc.): 26 MB
      2m 33.95s: OutputDisc: BDMV
      2m 33.97s: OutputTarget: BD50
      2m 33.97s: OutputVideo: 1080p/i
      14m 36.67s: Output group estimatedblock size
      14m 36.68s: video cannot be compressed
      14m 36.70s: video cannot be compressed
      16m 11.24s: info: bluray read data end
      65m 50.98s: DriveX msg: remove media in driveX E.
      65m 51.92s: UILog:MsgWork:current work finish : 3
      65m 51.92s: UILog:Run Work to end.
      65m 52.71s: Source managerpen source flag:1,0,1,1,1
      353m 08.61s: Source managerpen source flag:1,1,1,1,1
      354m 17.68s: Exit process: stop running.
      354m 17.68s: Exit process: preview pfn_releaseplayer end
      354m 17.77s: Exit process: preview pfn_deinit end
      354m 17.78s: Exit process: preview FreeLibrary end
      354m 17.79s: Exit process: finish MainUI.
      354m 18.36s: Exit process: finish FreePref.
      354m 18.36s: Exit process: finish AVEditWrap Release.
      0m 00.06s:
