There is an error while using Full Disc (BD50) from an iso,pls kindly advise what is the error and reason for this.
(2017/06/10 11:27:19)
0m 00.27s: Init Public log : enabled.
0m 00.28s: Init Private log : finish.
0m 00.29s: App info: 2016-10-21
0m 00.29s: App info: 9.3.1.9 9319 Official
0m 00.30s: Init CrashReportSettings : enabled.
0m 00.31s: Init DVDInfo_Log : enabled.
0m 00.31s: Init Qt_Log : disabled.
0m 00.32s: --- 3D implement select : Use default implement ---
0m 00.68s: Profile Manager :: Begin Load Profile
0m 00.75s: Qt Translator file load success
0m 00.75s: App info: client type 2.
0m 00.80s: MobilePlay load: preload successful.
0m 00.84s: MobilePlay load: Load successful.
0m 00.85s: set code page : .0
0m 00.85s: Init process: Transfer settings successful.
0m 00.86s: info: check logpath= C:/Users/Raymond/Documents/DVDFab9/Log/
0m 00.86s: info: _check_gpu is running ...
0m 05.63s: Profile Manager :: End Load Profile
0m 06.61s: info: check_gpu run successful
0m 06.62s: info: recommand= 67960832, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 4
0m 06.62s: GPU check: GPUAccelerate-0X40D0005
0m 06.62s: GPU check: GPUAccelerate setting-0X40D0000, 0X40D0000
0m 06.63s: GPU check: CUDA cap-0X0
0m 06.63s: GPU check: Support coreavc decode-0
0m 06.63s: GPU check: Lighting shrink status-1, 1
0m 06.64s: GPU check: Graphics info 1: Intel(R) HD Graphics 4600 : 10.18.14.4414 : 17,5
0m 06.65s: Init process: Load config successful.
0m 06.65s: Init process: Windows os type is 64bit System Windows 8.1 Build 9600.
0m 06.65s: Init process: command line in is
0m 06.70s: Reg check: Parse string: ( 2:8000000000 )( 11:8000000000 )( 20:8000000000 )( 50:8000000000 )( 80:8000000000 )( 21:8000000000 )( 22:8000000000 )( 60:8000000000 )( 70:8000000000 )( 61:8000000000 )( 62:8000000000 )( 55:8000000000 )( 95:8000000000 )( OV: )( BV: )( S: )
0m 06.71s: Reg check: Option check status-Local
0m 06.71s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:1 )-( Blu-ray to DVD:1:1 )-( DVD to Blu-ray:1:1 )-( File to DVD:1:1 )-( File to Blu-ray:1:1 )-( File Mover:1:1 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:1 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:1 )-
0m 06.72s: App info: language type ENU.
0m 06.72s: App info: Install path C:/Program Files (x86)/DVDFab 9/
0m 06.72s: Init process: Set account info to DriveX.
0m 06.73s: Export Blu-ray source information report : enabled
0m 06.73s: Init process: Init GPU settings successful.
0m 06.73s: connect plugin info : start.
0m 08.03s: Reg check: Times of cinavia connecting error is: 0
0m 08.04s: Reg check: Start get sys number.
0m 08.05s: Reg check: Serial number is: 2c-4d-54-69-06-d7
0m 08.05s: Reg check: Connect type is: 0
0m 08.06s: error curl post: URL using bad/illegal format or missing URL
0m 08.07s: error curl post: URL using bad/illegal format or missing URL
0m 08.42s: Init preview: Begin init preview play engine.
0m 08.42s: Init preview: Begin init preview play engine(Internal).
0m 08.53s: connect plugin info : 1:1
0m 08.62s: Init preview: Init internal engine successful.
0m 09.11s: Reg check: Connect test successful.
0m 09.12s: Reg check: Disable ssl connect for test.
0m 09.12s: error curl post: URL using bad/illegal format or missing URL
0m 09.13s: Reg check: Times of connecting error is: 2
0m 09.13s: Reg check: Get registration info failed, the return string is:
0m 09.16s: Burn engine: start init.
0m 09.17s: Burn engine: set log folder.
0m 09.17s: DVD: init read settings.
0m 09.17s: DVD: init write settings.
0m 10.07s: BD: init read settings.
0m 10.08s: BD: init write settings.
0m 10.08s: bd set region A
0m 10.09s: Burn engine: config engine type-0 begin.
0m 10.09s: Burn engine: config engine type-0 end.
0m 10.10s: Burn engine: writer count 2.
0m 10.10s: Burn engine: 0- D:\ [HL-DT-ST BD-RE WH14NS40 1.03 (Scsi)].
0m 10.10s: Burn engine: 1- E:\ [PIONEER BD-RW BDR-205 1.02 (Scsi)].
0m 10.11s: Burn engine: end init.
0m 10.48s: Init process: Init setting page successful.
0m 10.49s: QtLog Mode = false
0m 10.49s: Show ProductsInfo Dlg 2
0m 14.62s: Show UI Step 3
0m 14.62s: Start show MainUI.
0m 14.63s: UI manager: switch to Copy mode.
0m 15.41s: Init process: init main ui successful.
0m 15.79s: Init process: show main ui successful.
0m 15.80s: DriveX msg: Init driveX D with I/O mode: 0
0m 15.80s: DriveX msg: Init driveX E with I/O mode: 0
0m 15.90s: opening drive D
0m 15.92s: opened i/o
0m 15.92s: Source manager
pen source flag:1,1,1,1,1
0m 15.93s: opening drive E
0m 15.96s: opened i/o
0m 15.99s: Source manager
0m 16.00s: Source manager
1m 07.18s: set folder C:/Temp/Japan/m3/BDMV/ with type 2
1m 07.19s: opening folder C:/Temp/Japan/m3/BDMV/
1m 07.20s: set folder C:/Temp/Japan/m3/BDMV/ with type 2
1m 07.21s: opening folder C:/Temp/Japan/m3/BDMV/
1m 07.25s: Source manager: add source id 0.
1m 07.31s: bd set region ?
1m 07.31s: Source open status
VD Yes, 2223-7-6
1m 07.31s: Source open status:BD Yes, 2223-7-6
1m 07.32s: bd set region ?
1m 07.54s: got bdmv
1m 07.56s: blu-ray 2C1238BEE1C6D47C376A5AAC4B3091B8AC963DE1
1m 07.57s: cert BEE=0x00 same
1m 08.93s: D 3CCF822C
1m 08.99s: E FFE7CECE
1m 09.02s: main playlist 00002.mpls
1m 09.03s: selected region A
1m 09.03s: bd set region A
1m 11.10s: got extended bdinfo
1m 11.10s: TitleInfo : BD Parse Clone Title WARRING. title ID = 0
1m 11.11s: TitleInfo : BD Parse Clone Title WARRING. title ID = 1
1m 11.11s: TitleInfo : BD Parse Clone Title WARRING. title ID = 2
1m 11.12s: TitleInfo : BD Parse Clone Title WARRING. title ID = 3
1m 11.13s: TitleInfo : BD Parse Clone Title WARRING. title ID = 4
1m 11.14s: TitleInfo : BD Parse Clone Title WARRING. title ID = 5
1m 11.14s: TitleInfo : BD Parse Clone Title WARRING. title ID = 6
1m 11.15s: Cinavia : no cinavia repair data.
1m 11.17s: Source manager: open successful.
1m 11.91s: construct video_thumbnail error: source invalid_source_file_index
1m 11.91s: construct video_thumbnail error, so can not get thumbnail.
1m 11.91s: Work manager: create BD writedata work 0 with source 0 and uiinfo 0.
1m 11.92s: construct video_thumbnail error, so can not get thumbnail.
1m 11.93s: construct video_thumbnail error: source invalid_source_file_index
1m 11.93s: construct video_thumbnail error, so can not get thumbnail.
1m 11.94s: construct video_thumbnail error, so can not get thumbnail.
1m 11.94s: construct video_thumbnail error: source invalid_source_file_index
1m 11.95s: construct video_thumbnail error, so can not get thumbnail.
1m 11.95s: construct video_thumbnail error: source invalid_source_file_index
1m 11.96s: construct video_thumbnail error: source invalid_source_file_index
1m 11.96s: construct video_thumbnail error, so can not get thumbnail.
1m 11.97s: construct video_thumbnail error: source invalid_source_file_index
1m 11.97s: construct video_thumbnail error, so can not get thumbnail.
1m 12.00s: Source manager: select video files for open.
1m 12.01s: Source manager: this source is exist, source id 0.
1m 12.04s: Source manager
2m 00.03s: UILog:OnMsgToolbar_Start
2m 00.04s: UILog:Msg Start : ready start
2m 00.04s: UILog:Msg Start : start test run work
2m 00.04s: UILog:right button to null, work falg = -1
2m 00.09s: UILog:Msg Start : run work
2m 00.10s: UILog:Run current Work.
2m 00.10s: UILog:Begin work copy or converter.
2m 00.11s: UILog:start running at thread.
2m 00.11s: UILog:return flag at start running at thread ok.
2m 00.20s: UILog:MsgWork:WorkStatus_Start
2m 00.20s: build iso from C:/Temp/Japan/m3/ with MyBurn
23m 40.91s: UILog:MsgWork:current work finish : 3
23m 40.99s: UILog:Run Work to end.
29m 18.77s: Source manager
29m 21.10s: Source manager
31m 47.94s: Source manager: select video files for open.
31m 47.98s: opening iso C:/Temp/Japan/WAR/WAR.iso
31m 47.98s: got max lba 20748031
31m 47.99s: got disc type 20
31m 47.99s: type Blu-ray BDMV
31m 47.99s: volume label THE WARLORDS
31m 48.03s: Source manager: add source id 1.
31m 48.04s: bd set region ?
31m 48.05s: Source open status
VD Yes, 2223-7-6
31m 48.05s: Source open status:BD Yes, 2223-7-6
31m 48.05s: bd set region ?
31m 48.06s: internal path d:/BDMV/
31m 48.07s: aacs 1 bd+ 0
31m 48.19s: got bdmv
31m 48.23s: blu-ray 2C1238BEE1C6D47C376A5AAC4B3091B8AC963DE1
31m 48.39s: cert BEE=0x00 same
31m 49.73s: D 3CCF822C
31m 49.82s: E FFE7CECE
31m 49.88s: main playlist 00002.mpls
31m 49.89s: selected region A
31m 49.89s: bd set region A
31m 49.90s: got vuk
31m 49.91s: got unit key 1
31m 51.22s: StealthyClone with BluPath
31m 51.30s: got bdmv
31m 51.82s: stream(27,2,3)/clip(27,2,1) infos are not the same, using clip info to regulate it.
31m 51.88s: stream(27,2,3)/clip(27,2,1) infos are not the same, using clip info to regulate it.
31m 52.04s: got extended bdinfo
31m 52.04s: opened blu-ray
31m 52.04s: TitleInfo : BD Parse Clone Title WARRING. title ID = 0
31m 52.05s: TitleInfo : BD Parse Clone Title WARRING. title ID = 1
31m 52.05s: TitleInfo : BD Parse Clone Title WARRING. title ID = 2
31m 52.05s: TitleInfo : BD Parse Clone Title WARRING. title ID = 3
31m 52.05s: TitleInfo : BD Parse Clone Title WARRING. title ID = 4
31m 52.06s: TitleInfo : BD Parse Clone Title WARRING. title ID = 5
31m 52.06s: TitleInfo : BD Parse Clone Title WARRING. title ID = 6
31m 52.06s: Cinavia : no cinavia repair data.
31m 52.08s: Source manager: open successful.
31m 53.11s: Work manager: create BD fulldisc work 1 with source 1 and uiinfo 1.
31m 53.12s: bd-fulldisk : FillWorkData not rmove audio
31m 53.13s: bd-fulldisk : FillWorkData not rmove audio
31m 53.14s: bd-fulldisk : FillWorkData not rmove audio
31m 53.15s: bd-fulldisk : FillWorkData not rmove audio
31m 53.16s: Source manager
31m 53.63s: bd-fulldisk : FillWorkData not rmove audio
31m 59.87s: bd-fulldisk : FillWorkData not rmove audio
31m 59.88s: bd-fulldisk : FillWorkData not rmove audio
32m 00.14s: bd-fulldisk : FillWorkData not rmove audio
32m 20.42s: bd-fulldisk : FillWorkData not rmove audio
32m 20.67s: bd-fulldisk : FillWorkData not rmove audio
32m 24.75s: UILog:OnMsgToolbar_Start
32m 24.76s: UILog:Msg Start : ready start
32m 24.76s: UILog:Msg Start : start test run work
32m 24.82s: UILog:Msg Start : run work
32m 24.82s: UILog:Run current Work.
32m 25.19s: UILog:Begin work copy or converter.
32m 25.22s: UILog:start running at thread.
32m 25.24s: UILog:return flag at start running at thread ok.
32m 25.24s: bd-fulldisk : FillWorkData not rmove audio
32m 25.27s: BD FullDisc watermark flag: 0
32m 25.27s: UILog:MsgWork:WorkStatus_Start
32m 25.27s: bd-fulldisk : RunTask 0 audios
32m 25.28s: Blu-ray Copy: Full Disc
32m 25.29s: Source: d:/BDMV/
32m 25.29s: SourceSize: 40512 MB
32m 25.30s: RemoveHDAudio: 0
32m 25.30s: OutputSize: 46100 MB
32m 25.31s: OtherSize (CLPI, JAR, etc.): 171 MB
32m 25.31s: OutputDisc: BDMV
32m 25.32s: OutputTarget: BD50
32m 25.32s: OutputVideo: 1080p/i
32m 25.63s: Output group estimatedblock size
32m 25.64s: video cannot be compressed
32m 25.65s: video cannot be compressed
32m 25.66s: video cannot be compressed
44m 52.84s: error reading d:/BDMV/STREAM/00002.m2ts, fileSize 37719724032, copied 19177930752, dwToCopy 1572864
44m 58.70s: UILog:MsgWork:current work finish : 2
44m 58.80s: UILog:Run Work to end.
53m 53.58s: bd-fulldisk : FillWorkData not rmove audio
53m 53.59s: bd-fulldisk : FillWorkData not rmove audio
53m 53.60s: bd-fulldisk : FillWorkData not rmove audio
53m 53.61s: Source manager
53m 54.10s: bd-fulldisk : FillWorkData not rmove audio
53m 55.62s: Source manager
54m 14.23s: Exit process: stop running.
54m 14.23s: Exit process: preview pfn_releaseplayer end
54m 14.31s: Exit process: preview pfn_deinit end
54m 14.32s: Exit process: preview FreeLibrary end
54m 14.32s: Exit process: finish MainUI.
54m 14.47s: Exit process: finish FreePref.
54m 14.48s: Exit process: finish AVEditWrap Release.
0m 00.03s:
1m 07.54s: got bdmv
31m 49.90s: got vuk
0m 00.03s:
