I have both 5 and 6 installed , about a week ago and after installing 6 again , it no longer works. I have deleted the folder it installs in and downloaded it again. When I click on the icon nothing happens. 5 still works fine. except now it seems to ask for Double Layer discs, which I don't have and am only backing up the main movie.
DVDFab: Program 6. no longer works
Posting for help and then returning 2 months later is not a good way to get help. Try right clicking the install and choose install as admin and same goes for desktop icon right click it and choose run as administrator. Maybe make sure your anti-virus/firewall is turned off as well. Anyway that all I say since you return after 2 months to complain again. Most people will continue after they post for help not post, leave and then come back 2 months later looking for a solution to be posted
Posting for help
I have sent emails to support with 1 return email, which I followed . When I replied to the support email I got nothing back.. that was also the same time frame. Constantly posting the same problem over and over is not something I enjoy doing. This problem has been a thorn in my side, and there is no posted solution. It seems more users also have this problem. I really enjoyed the product until using v6.
virus software
I have run the virus and spyware software to clean the computer, after that I disabled them, ran the install and still a no go. I have the v6 key, but the program never asks for a key. It never starts up. If I take the email and try to install the key from there , I get a message that it has no association. If I can install 5 anytime, what got changed in 6. If there is a hidden file for the trial that might be screwing this up, please tell me what the file is and I will delete it.
When you click on the key and it says it has no association, in the pop up select the bottom choice (not the webservice if memory serves) and browse to your programs folder on the C: drive (or the drive windows is installed on) and select the DVDFab folder, inside it you should see DVDFab6.exe, click that to associate your V6 key with version 6 of Fab. (Note: if running a x64 bit version it will be in Program files x86) hope that solves it for you.
Are you installing and registering as administrator?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Same situation
I'm in the exact same boat, I have had DVDFab 5 5.2.3.2 installed and functioning, but can't even get DVDFab 6 to start to even try out the 30 day trial. I uninstalled everything for both 5 & 6 (hidden directories, registry entries, etc.) by hand - no go. Turned off avast AV, install/run as admin, Intel P4 2.53GHz, 1GB RAM, installed on C:,... stumped.
