Folder Redirection for DVDFAB Temp and SceneData
    Other Folder Redirection for DVDFAB Temp and SceneData
    Have been through and sett everything to redirect from the default "My Documents\DVDFab10" folder to another local drive. However I am still getting data written to one folders.
    "MyDocuments\DVDFab10\SceneData" - I have been through the settings a number of times no and can't find anything else I can change. If there something in a config file I can adjust manually?
    Running 10.0.5.1 on Windows 10, using BluRay Ripper
    I suspect this is a hard-coded default that (when it was added) was not linked to use the other temp or record file choices you can make in Common Settings. These are just xml files where DVDFab records settings and records that you may wish to use again (like output target settings and Ripper options you used) and similar dynamic content. I do not see a reason they could not be written to whatever location is used for the other Document writes, like the logs. Will pass it up the food chain.
      We will check it ASAP, the folder path should be set manually.
        Thanks both - will wait on your response
          I am also looking for the MyDocuments\DVDFab10\SceneData and MyDocuments\DVDFab10\Temp\MediaServer setting, I cant find these anywhere to stop it creating the dvdfad folder in MyDocuments.
          I am running 10.0.5.2 x64 version
            Developer is checking,waiting for fixed.Thanks for your feedback.
