Just installed the newest version of FAB and it looks like it's gonna work! But, while we were without cable/internet service, we tried watching some movies on my Parent's newer Sony BD Player. Tried 3 different titles, but the player said disc was unplayable. Only had the player about 6 months. It's a Sony BDP-S3700. Just tried a disc on my Sony BDP-S390 (few years older) and no problem. Newer software on the 3700?
discs unplayable
Have you tried playing them in your PC with a software player?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
You may have a media/burning issue as suggested earlier by october262. I would slow the burn speed down to 2x and see if the Sony player will tolerate it. Also, you can try burning with ImgBurn if you are using something else. Be sure to enable OPC in ImgBurn settings. If the discs play elsewhere, I don't believe there is anything really wrong with them.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
