I copied this DVD with Region code 2 and apparently, DVD Fab removed the code. I burned it but my dvd player displays a message that reads "unsupported disc". What Am I doing wrong?
Region code
could be a NTSC - PAL issue
you removed the region code but your tv and dvd player cannot display & play PAL format
does the burned disc play on your computer ?? some dvd players do have a NTSC - PAL setting
that allows the player to play PAL discs.Last edited by october262; 09-26-2017, 03:59 AM.
Put the disc (the copy) into your PC, Make an empty folder on your desktop named IFO. Open the disc in Windows Explorer and copy all the IFO files from the VIDEO_TS folder to the empty folder on your desktop. Now compress the folder to a zip or rar file and attach it to a post. Anything is just a guess without this information.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
