so just installed the beta today of 10.0.6.3 and noticed that I can no longer do a full disc iso, it always adds bd25 tag next to clone/burn, anyone else having this issue?
clone/burn - full iso removed in beta?
Are you using Full Disc with ISO output or Clone mode? Clone will always ask for the same size disc as the original. If the original is a single layer BD25, it will ask for that.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Clone is a 1 to 1 copy. Nothing is changed or compressed so if you are cloning a BD25 that's what it will produce and nothing else. If you want to determine the output size use "Full Disk" and you'll be able to change the output size.How to post the internal log
