UHD COPY and UHD RIPER options.
    Good Morning,
    As I see that there are implemented two new Modules for the recording and ripping of UHD, I would like to know if they will take into account in the future the possibility to include the option so that the user can substitute audios in them, as you will know there are distributors that include in the audio UHD ac3, while on the Blu Ray are in dts-hd Master Audio, it is clear that the audios to be replaced must have been previously synchronized by the user for the new footage if required, is as currently with the Subtitle..
    regards
    Good feedback, moving your thread to General Questions. I think we can anticipate some enhancements as the product(s) evolve.
