No audio on WMP
    No audio on WMP
    Hi, After burning DL DVD, WMP has no audio on the play back; it does have audio on VLP player, however, I'd like others (and myself) to be able to use WMP. I remember I had a similar problem a couple of years ago and downloaded K-lite codecs and it did work....I see they are still listed in my Program lists, however, no audio; do I have to use a particular codec in this K-lite application? Thanks, Gil
    You need to download and install the proper codec. Try ffdshow (free) if K-Lite did not work. Or just use VLC as your primary media player.
      Thanks, but now.....another similar problem! After using ****** application to convert Youtube's video clip from FLV to AVI and downloading to my PC, the video plays, but, again, no audio in either WMP OR VLC, so do you know how to make sure the audio is also converted and/or downloaded from Youtube to my PC > players? As I mentioned, earlier, I have K-lite installed, which includes AC3 and ffdshow.
      TIA, Gil
        Originally posted by Gil410s View Post
        Thanks, but now.....another similar problem! After using vixy.net application to convert Youtube's video clip from FLV to AVI and downloading to my PC, the video plays, but, again, no audio in either WMP OR VLC, so do you know how to make sure the audio is also converted and/or downloaded from Youtube to my PC > players? As I mentioned, earlier, I have K-lite installed, which includes AC3 and ffdshow.
        TIA, Gil
        This is not an appropriate question to ask on a DVDFab forum. Please refrain from such posts !!!
