Duplicate program???
    Purchase Problem Duplicate program???
    I purchased DVD COPY 10 for my home computer. Can I get a duplicate program for my laptop or is that not allowed?
    You can install and use your license on as many PCs as you like, but only one can be Authorized at a time. If you authorize it on your desktop normally, but want to take the laptop on a trip, you must use the "Deauthorize" option in the DVDFab Settings menu before you leave, then the "Authorize" option on the laptop and reverse the process when you return. It only takes a few seconds, but if that is inconvenient, you can purchase additional Authorizations if desired for a small fee and have it always active on both. See below:
    Click image for larger version  Name:	1-011DEAUTH.png Views:	7 Size:	32.2 KB ID:	349626
