I'm noticing that all the temp folders default to using OneDrive. Why is this & how do you turn it off?
How To Turn Off Default To OneDrive
The temp file location is controlled in Common Settings->General. It will remember whatever you set but the drive must be available when you start DVDFab.I'm not aware of any changes to the default, which is in (my)Documents. If you have that folder set up to go to OneDrive, then Fab will also unless you specify another location in Fab Settings.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
