Rental DVD
    Rental DVD
    I have a BR DVD with the word RENTAL on it and Fab doesn't "see" it in the drive. I think I read somewhere that these dvd's cannot be ripped. Does this affect Fab? If not how can I rip this disc. The tiltle is Jason Bourne Thanks
    DVDFab can read discs like this, normally with no problem unless the disc is damaged in some way. Can you play the disc on your PC with a software player? Many users purchase the off-rental discs and process them with no problem.
      I just purchased a rental disc just like you stated and it ripped fine for me. Might also be a dirty drive or disk. You can also try using passkey if you have it.
        Found problem. My laptop doesn't have a BR player that's why it didn't see the DVD. My bad. Signals and jimczyz thanks for the responses.
