licensing model...
    licensing model...
    I have bought DVDfab. Can i use it on 2 PC's at the same time? I have one at home and one in the office.
    you must be buy Multi-Computer License. 3-Computer License $30
    5-Computer License $50
      The above reply is not fully correct. You can install and use DVDFab on as many machines as you like without buying anything, but you must Authorize and Deauthorize the DVDFab installation on each machine as you change locations or machines. For example, if you want to use the one at the office for the day, just deauthorize the home unit before you leave and Authorize the one at the office when you get there. Then Deauthorize it before you leave for home. If that is too much of a hassle, you can buy the additional authorizations if you want them, then no more re-authorizing is necessary.
      The authorization management controls are found here:
Name:	1-011 AUTHORIZEMGR.png
        thanks for the info.
